Read dash dump and post here with ezs dump.
I have a W169 and change Elv and Ezs with org Avdi
that’s not the problem. Car start and run.
but dash I can read odo but show on dash only ———
i make Ezs & Elv virgin and prog dash >>> no success
I check vin >>>> both same and ok ( after I prog vin new in EZS }
i check odo in Ezs >>>>> 0 km ( think is the problem )
i prog with r270 line 410, 470 & 480 Manuel from a other post >>>> no success
have a m8 here to solve this problem ?
thnx in advance
JFR-Tuning (27th March, 2020)
Or post SSID from ezs -read with avdi.
Ok will do read Ssid from Ezs . Cash dump I don’t have here car far away
you have 2 way. 1-0 km in dash and adapt with das. 2-to put ssid in dash dump - #29-#2C
JFR-Tuning (30th March, 2020)
put 0 km on dash
and adapt dash with das ore avdi
ALL TUNING.
THE BEST OR NOTHING. THANKS + REPUTATION .
Solved for all
thnx for help i will edit this Post top learn for all
if y change Ezs dash show ——-
you Must make 0 km in Cash and Ezs
than Go with DAS. In Dash advance > Ansteuerungen > Gesamtliste aller Ansteuerungen
typ the Point
Ezs Immo data learn ( Inbetriebnahme, adapt Dass you Need online Connection )
result Must be : 1
now ist Show 0 km In Dash
take a avdi and make Right Kilometer in Dash an all ist fine
job done
