dump edc17cp52 citroen jumper 3.0
Mm interesting file, 6 speed but with space for 8? For some reason the ratios appear to be duplicated:
294D3E & 294D40- PT_rTraGear1_C
294D52 & 294D54- PT_rTraGear6_C etc...
aslex (27th March, 2020)
16 bit factor of 0.01. They're not the most precisely done things, if they were neither would cruise control work for you in 4th and 5th.
Just lengthen 6th for 0.6 to 0.55 or until it works.
You also may need to adjust the 6 gear V/N min and max ratio windows that are just afterwards (16 bit factor 0.00001), can't figure out which one.
aslex (28th March, 2020)
Now there's some useful information.
If I see it correctly 294D94 is Tra_rVn6H_C or the upper limit for the V/N ratio in 6th. Currently it is 0.05. Looking at the previous gearbox V/N ratio for example 6th- 115.7kmh/2500rpm= 0.04628 therefore it falls within the acceptable window for gear plausibility. However on the new gearbox 143/2500= 0.0572 which is outside the window and may therefore be the reason for the issue.
So I would recommend increasing to 0.06 and trying that.
Thank you very much for your help!
Editing the upper limit value at 0.06 helped. Cruise control began working in sixth gear.
DiegoStud (29th March, 2020)
I have same problem. I change gearbox in fiat ducato and cruise not work on 6 gear :/ is such a change enough?
Hello ! I have the same problem on my Ducato 3.0 2015. With what program i can change the speed ratios and what can i do. Please help me, thank you !
