Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 60
  1. #16
    Dec 2018
    edc17 in renault can do eeprom for auto-sync. and no more work is required
  2. The Following User Says Thank You to Catalizator For This Useful Post:
    Louislesinge (4th April, 2020)
  3. #17
    Apr 2010
    Can you helpme Catalizator?
  4. #18
    Dec 2018
    as requested,virgin eeprom
  5. The Following 2 Users Say Thank You to Catalizator For This Useful Post:
    arielcom (5th April, 2020), Louislesinge (4th April, 2020)
  6. #19
    speedy100's Avatar
    Jul 2010
    Athens
    Quote Originally Posted by Catalizator View Post
    It will be good to know if it worked OK so we all learn something new
    Best Regards
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
  7. The Following User Says Thank You to speedy100 For This Useful Post:
  8. #20
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    @Catalizador: I rather think the same as @speedy100, i mean autocoding works with EDC17C11 on Trafic II/Vivaro but not sure it will be the same on Master III/Movano. It certainly needs to be learned with Clip
    Anyway, wait and see...
    Greetings,
  9. #21
    Dec 2018
    if a comrade from Paraguay does not make mistakes while writing ecm, and uch is in the programmed state with the keys, everything will be fine. I only work with renault, and over the years of repair have tested many repair methods.
  10. #22
    Jun 2017
    French Jungle
    Ok, but by the way when you mount virgin ECU on Twingo II Clio III and many other Renault it doesn't learn antitheft code just making ignition ON (the way it was in older cars like Scénic/ Mégane 1 for exemple) , ECU needs you to send command with CLIP , that is what speedy100 and me are doubting about.
    Another thing, EDC17C11 is mounted in Trafic II mark 3 (>2010) so problem could be the same...
    Saludos,
  11. The Following User Says Thank You to Louislesinge For This Useful Post:
    albertros (7th April, 2020)
  12. #23
    Apr 2010
    Hi, same problem Catalizator. i did write your dump using ktag sussesfull. do you have another possibilities?
  13. #24
    Dec 2018
    remove and read ecm and compare the data with my dump.
  14. #25
    Apr 2010
    when i write the data its same. but after put the ecu in car and put contact with the key it change and have 135 differences.
  15. #26
    speedy100's Avatar
    Jul 2010
    Athens
    Quote Originally Posted by arielcom View Post
    Try by reprogramming the virgin fie in the ECU and then use CAN CLIP to adapt it and see what happens.
    Best Regards
  16. #27
    Dec 2018
    [QUOTE = arielcom; 3839829] когда я пишу данные, то же самое. но после того, как поставить ЭБУ в машину и поставить контакт с ключом, он меняется и имеет 135 отличий. [/ QUOTE]
    write down my dump, then read ktag again and compare the values. I suspect your programmer. I also think there is a malfunction in the car itself.
    when installing ecm, it responds to diagnostics, read errors?
    more information. this will help solve your breakdown and speed up repairs
  17. #28
    Dec 2018
    https://www.digital-kaos.co.uk/forum...73#post3759373
    I leave confirmation here that my file should work
  18. The Following User Says Thank You to Catalizator For This Useful Post:
    Louislesinge (7th April, 2020)
  19. #29
    Sep 2019
    no passs report
  20. #30
    Apr 2010
    Quote Originally Posted by speedy100 View Post
    Best Regards
    i cant get CLIP , sorry. My friend didnt arrive. sorry
    but in 2 days i will have renolink 1.87 with red cable. can i use it for this?
