Results 1 to 5 of 5
    dd1's Avatar
    Aug 2014
    Default BMW DME ME9.2 BDM
    Hi everyone, trying to swap a dme me9.2 bmw x5 e53, 2003, with a used one. i can write with the xprog, can not write. i need to bypass the WP so that i can write the file back. i am using xprog. wound a picture of it but it is not what i have. i supplied the 3.3v too and no luck. can someone help me with this process? thank you in advance
    speedy100's Avatar
    Jul 2010
    Athens
    Quote Originally Posted by dd1 View Post
    Hello,
    Here is BDM pinout for Bosch ME9. I hope it will help You.
    Best Regards
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
  3. The Following User Says Thank You to speedy100 For This Useful Post:
    dd1 (27th March, 2020)
    dd1's Avatar
    Aug 2014
    thank you, i kind of managed to bypass the WP and now it writes but verifies NOT OK. should i worry about this?
    speedy100's Avatar
    Jul 2010
    Athens
    Yes it should verify OK.
    Make sure all connections are clean and very well connected...
  6. #5
    DK Veteran zoro1's Avatar
    May 2010
    Bulgaria,Sofia,Vidin
    you need to erase data before writing!
    Large nations behave like gangsters ,and young as prostitutes !
