hi
hi
I read now again, is ok?
Now looks good. Here is repaired eeprom.
Make sure information below is correct before writing back.
VIN: WBAPG11030E550176
FA: E90_#0310&BCAT%0A76*PG11$1CA$1CB$1CC$1CD$230$249$2 58$2K5$320$321$322$423$428$431$441$464$465$494$4AE $4AT$502$507$520$521$522$524$534$540$548$563$5AC$6 44$663$688$698$710$7MD$7R7$7RS$801$851$863$879-A090
Production date: 05.05.2010
Programming date: ff.ff.ffff
HW-NR: 9206246 (Hardware part number)
SW-NR: ffffffffffff (Updated part number)
ZB-NR: ffffffffffff (Original part number)
S: 9230446 (Original part number)
lovinedi03 (28th March, 2020)
Hi guy
Can any one help please, trying to repair faulty frm3 module and require the eeprom file.
frm3r 6135 9230448
many thanks in advance
here is your eeprom mate
If i Helped you,use thanks and rep button to thank me back
jimmypoulin (21st February, 2023), techman1 (23rd April, 2020)
thank you, stay safe mate
Stelaras26 (18th May, 2020)
Hi I need software for frm3r 9263802-01 or sp-daten for e89 with this part number. I tried to read original p-flash and d-flash with clone xprog and I bought yesterday original Orange5 but ist the same bin. No changes on ich one. I was load my dump d-flash on side with d-flash to eeprom repair but i've got every time incomplite vin number. Enybody can help with this?
https://mega.nz/file/5x4miKCY#ADgiIc...Z0ulpiWLKVJhV0
My question is if I write p-flash from FRM with the same part number to my FRM that will good solution? I tried to write p-flash from another module but when I read it again d-flash is empty. What I'm doing wrong? Can enybody help?
physical d-flash is 32kb but all assigned for EEPROM emulation and by this reason D-flash is 0kb because all d-flash contains EEPROM emulation data.
If partition corrupted you cant read EEPROM data because emulation notwork. You read d-flash data and restore eeprom data.
ricked did you looking at my d-flash? Is it good or i was bad read it? Or maby somebody erlier tuned original d-flash file?
