What year, engine etc? Maybe you'll find something from there.
https://cardiagn.com/toyota/toyota-yaris/
rui (19th April, 2020)
Probably gear learnings lost after clutch replace... Automatic gearbox ecm need to be reprogrammed. Common issue on yaris mmt.
Hello.
thanks for the information and help.
When trying to make the adjustment, it stopped picking up and as many times as I could get it to work, I didn't put changes. So I decided to remove the gearbox and the clutch is worn out.
Due to the wear of the clutch, it can prevent the car from starting.
I was stopped and it is only now that I started working on the car, but then I give feedback on the problem.
I already fitted the new clutch and made all the adjustments, it already puts changes.
But the original problem is that it still has it, which is when I start, there is no current in the starter motor relay.
I have already checked the relay is in order and the wiring.
In the electrical diagram he mentions a diode that goes to the relay because I am having trouble finding where it is.
Has anyone had a similar problem?
thank you
the letter N does appear in the quandant. if I connect directly to the starter, I can drive the car.
the problem is when i press the start button it will not start, information will not reach the starter relay to start.
I have no faults registered.
