abu deab (2nd June, 2021), amor89 (14th December, 2020), danielbranquinh (12th March, 2021), golo (2nd June, 2021), mohamad1401 (28th March, 2020), nigrou (28th March, 2020), tehnosoftex (24th November, 2020)
Boot
Envoyé de mon SM-A310F en utilisant Tapatalk
abu deab (2nd June, 2021), masterskay62 (29th March, 2020), mohamad1401 (28th March, 2020), nigrou (28th March, 2020), richiebb (28th March, 2020)
RENAULT PRECODE CALCRenaultRadioCodeGen.zip
MEDIA NAV CAMERA
Menu detail Micom test MediaNav Evolution 2.0 version 1.0.13.2
Access the menu::mcmtest_activate.ini
MNE V2 1.0.13.2.368_r49:
PW1: "4620" (PASSWORD_TEST_MODE)
PW2: "0688" (PASSWORD_ENGINEERING_MODE)
PW3: "2047" (PASSWORD_VERSION)
abu deab (2nd June, 2021), gabriel pablo (11th April, 2020), golo (28th March, 2020), petku (28th March, 2020), tehnosoftex (24th November, 2020)
- Format a USB stick like “FAT32”
- Open the USB stick
- Download the files from the link, extract them (not open directly) and copy directly in the main folder.(The pass for the file is: lisandru.eu) or create new file like this:
- MN1 & MN2 6.x.x: mcmtest_activate.ini (menu Micom+ WinCE)
- MN2 7.x.x – 8.x.x: mcmtest_activate.ini ( menu Micom+ WinCE ), mcmtest_activate_4nng.ini MENU MICOM)
- MN2 de la 9.x.x: mcmtest_activate_4medianav.ini (Micom + WinCE), mcmtest_activate_4nng.ini (only MICOM)
- MN3 de la 1.0.x.x: mcmtest_activate.ini ( complete menu MICOM )
- Load the USB stick in the main slot from Media Nav
- Startup the navigation EVOLUTION Contact, turn on, volume +, volume – and click empty USB for MEDIANAV or go to Settings → System → System Version [PAGE 2]) for MEDIANAV EVOLUTION
- Now you need to press in sequence bellow 1-5 areas
Dacia Renault points of touch for micommanager activation on MEDIANAVEVOLUTIONOnce done, a new screen will appear, entitled “Test Mode”
At this point we will have to follow these steps:
For version 3.x.x-8.x.x:
- Type 0362
- Press OK
- Delete with the right button
- Type 3748
- Press OK
For version 9.x.x
The access codes to the Micom Manager for the new versions 9.1.1 and 9.1.3 are the following:
- Type 2383
- Press OK
- Type 3748
- Press OK
Update!! For version 1.0.xx.x
Vers.1.0.13.1.366_r35:
- Type 8457
- Press OK
- Type 7777
- Press OK
- Type 5031 (PASS version)
Vers.1.0.13.1.366_r36:
- Type 2895
- Press OK
- Type 5751
- Press OK
- Type 9895 (PASS version)
Vers.1.0.13.1.366_r39:
- Type 6835
- Press OK
- Type 9377
- Press OK
- Type 5822 (PASS version)
Vers.1.0.13.2.368_r49:
- Type 4620
- Press OK
- Type 0688
- Press OK
- Type 2047 (PASS version)
Vers. 1.0.13.3.369_r60 :
- Type 9777
- Press OK
- Type 1757
- Press OK
- Type 7817(PASS version)
Or TRY Quick launch of the MicomManager configuration screen (only not safe mode)
Press 10 times in a row on the area shown in the picture at number 3
And you will immediately enter MicomManager without entering any codesNow the Micom Manager is opened. To access the complete configuration screen press the “MICOM TEST” button.
MICOM TEST activation Dacia RENAULTAt this point, we need to be aware of what we are going to click, because we could do damage that is difficult (or at least very cumbersome) to remedy.
For ease of reading, I will describe only the mainly 21 most important keys in row order, from 1 to 21.
MEdiaNav Evolution Micom ManagerATTENTION: Don’t touch ever button “Virgin / Clear Virgin / ClrCnf. ” because is resetting your device.
- Guide line reversing camera
- Temperature display (off / ° C / ° F)
- ECO mode (deactive / active)
- AHA function (On / Off)
- GPS / Glonass
- Reversing radar: Sound (SND) + template (HMI Off / HMI R / HMI-FR) + SPK-FR ??
- TMC function (On / Off)
- Ignition type of the MN: ON (key on accessory: the station displays the time, engine on: the station displays the menu if presence of the BIC); AC (key on accessory: the station displays the menu)
- Color of the interface (M1-> renault; M0-> dacia)
- Activate “Road” mode, 4×4 screen (inclination, vehicle orientation) if in Dacia mode.
- Automatic transmission (ISR) or manual transmission (BVM) ??
- New emergency call function when airbags are triggered ??
- Choice of boot logo (at startup): for the choice to be effective, after clicking the left and right arrows, click on the button with the name of the selected logo, then restart MediaNav.
- Starting the remote engine ??
- Activation of the reversing camera (off / RVC) ?? + n ° 21 (?)
- Steering Wheel Remote Control: steering wheel remote control
- Push to talk: button on the steering wheel for voice commands
- Speaker (SPK) and tweeter (TWR) front (front) and rear (rear)
- Loudness
- Activation of the BOSE function (brand amplifier required)
- $ 17 single camera; $ 18 multi-view camera ??
Some functions require additional interfaces (BIC case for example).
At the end of the 6th line, 2 RVC and MVC buttons (necessary to activate the camera in version 8 and +?)
To change the logo, after having chosen, it is necessary to validate by a support.
UPDATE !! For the new Medianav Evo II 2019 we have :
Medianav EVO II Car Android Play 1.0.10.x.x
- Hard reset: CHANGES CHANGES
- Make virgin: ATTENTION! DO NOT TOUCH!
- TMC: INFO TRAFFIC (On Off)
- COL M0: GRAPHIC INTERFACE: M0-DACIA M1-RENAULT
- SND: REVERSE SENSORS (On Off)
- DAB: DAB SOURCE SELECTION DAB +
- $ 17-HJD_RVC: REVERSE CAMERA
- CP: CARPLAY (On Off)
- AA: ANDROID AUTO (On Off)
- SIRI: SIRI (On / Off)
- $ 00 DACIA: BOOT LOGO
- ADAC: activation cdb km (On Off) ???
- TEMP * C: TEMPERATURE (On / Off)
- AIR Active: AUTOMATIC AIR CONDITIONER (On / Off)
- ENG BVM: AUTOMATIC MANUAL CHANGE
- ECO: ECO (On Off)
- LDNS: LOUDNESS (On Off)
- MW On-LW On: MEDIUM WAVE LONG (On Off)
- ECALL Off: EMERGENCY CALL
- SWRC 4: STEERING WHEEL CONTROLS SETTINGS.
- DAB: DAB (On Off)
- RVC or MVC: REAR CAMERA MULTI VIEW CAMERA (On Off)
- GPS: GPS (On Off)
- SPK_R + TWR_F + TWR_R: ANT SPEAKER ANT E POST (On Off)
- PTT: STEERING VOCAL CONTROL
- 4WD: INFO 4X4 (On-Off)
- RES: Starting motor remotely ??? – For Russia maybe
- AHA: APPLICATION TO LISTEN TO MUSIC ONLINE FROM SMARTPHONE (On Off)
- BOSE: BOSE AMPLIFICATION “where provided” (On Off)
- WAKE: alarm or starting when unblock
- The commands with an asterisk are to be considered unknown.
abu deab (2nd June, 2021), diagun (7th April, 2020), gabriel pablo (11th April, 2020), tehnosoftex (24th November, 2020), Vetaxa (30th October, 2023)
MediaNav (MN1):
MediaNav Evolution (MNE):
MNE V2:
MN1 WinCE Desktop: 8005, OK, <<<<, 0362, OK
MN1 Micom Manager: 8005, OK, <<<<, 3638, OK
MN1 Versionsnummern: 8005, OK, <<<<, 1111, OK
MNE bis 8.0.5 WinCE Desktop: 0362, OK, <<<<, 6971, OK
MNE bis 8.0.5 Micom Manager: 0362, OK, <<<<, 3748, OK
MNE bis 8.0.5 Versionsnummern: 0362, OK, <<<<, 1111, OK
MNE ab 9.1.1 WinCE Desktop: 2383, OK, <<<<, 9065, OK
MNE ab 9.1.1 Micom Manager: 2383, OK, <<<<, 3748, OK
MNE ab 9.1.1 Versionsnummern: 2383, OK, <<<<, 1111, OK
MNE V2 1.0.13.1.366_r35 Micom Manager: 8457, OK, <<<<, 7777, OK
MNE V2 1.0.13.1.366_r35 Versionsnummern: 8457, OK, <<<<, 5031, OK
MNE V2 1.0.13.1.366_r36 Micom Manager: 2895, OK, <<<<, 5751, OK
MNE V2 1.0.13.1.366_r36 Versionsnummern: 2895, OK, <<<<, 9895, OK
MNE V2 1.0.13.1.366_r39 Micom Manager: 6835, OK, <<<<, 9377, OK
MNE V2 1.0.13.1.366_r39 Versionsnummern: 6835, OK, <<<<, 5822, OK
MNE V2 1.0.13.2.368_r49 Micom Manager: 4620, OK, <<<<, 0688, OK
MNE V2 1.0.13.2.368_r49 Versionsnummern: 4620, OK, <<<<, 2047, OK
MNE V2 1.0.13.3.369_r60 Micom Manager: 9777, OK, <<<<, 1757, OK
MNE V2 1.0.13.3.369_r60 Versionsnummern: 9777, OK, <<<<, 7817, OK
abu deab (2nd June, 2021), gabriel pablo (11th April, 2020), tehnosoftex (24th November, 2020)
Few month ago I tested this method and it worked well. It´s very important moment,
when the reset switch is pressed. Look at video very carefully.
Hello.
USB stick not recognized on a MediaNav 6.0.3
I have a problem reading usb keys on medianav 6.0.3,
I put several flash disks but nothing;
I succeeded in entering a Windows method 1/2/3/4/5 code
0362/6971 Embedded CE 6.0, medianav does not detect them,
Is there a solution for this problem.
thank you in advance.
