Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Oct 2017
    Ukraine
    Default mazDa 6 2016 gmn3-57k30
    I welcome everyone to this forum. Iprog read the block. I saw later that with an error. I got a problem with an error of 3000. Plus, I see that it’s not possible to clean the dump correctly. If there is a similar dump to mine. Put it here or by mail please. I have downloaded more than one dump from this block. After The block is identified, but there is no registration of the wincode and the name of the block. As I prescribe its native, everything is determined. lights up all abs tidy steering wheel all .thanks
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    You must do adaptation g-sensor I think ...
    You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
    If I helped, please, use magic buttons reputation+thanks.
    Best regards.
    Dragon
    Oct 2017
    Ukraine
    does not give
    slick_dick's Avatar
    Dec 2009
    Essex
    yes check abs for acceleration sensor calibration
    “There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
    Oct 2017
    Ukraine
    in the block abs does not
    Oct 2017
    Ukraine
    I begin to calibrate in the abs block, and the program stops the calibration of the sensor. if the pillow block will be working without error 3000. then everything will be ok
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Here you go Viiktor 2016 mazda 6. Hope this helps.
    IF I HELPED YOU PRESS THE " T " BUTTON
  8. The Following User Says Thank You to PSAcars For This Useful Post:
    joejam (9th April, 2020)
  9. #8
    Oct 2017
    Ukraine
    The firmware does not produce anything. I will alter all the flash. I’ll write about the finished work later
  10. #9
    Oct 2017
    Ukraine
    read the full
  11. #10
    Oct 2017
    Ukraine
    in the block you need the original flash. playing with other files is a waste of time. maybe someone hid somewhere full files. this can save the situation. a rare configuration block. I don’t even know where to look. thanks
  12. #11
    Apr 2017
    Poland
    you check this file
  13. #12
    Oct 2017
    Ukraine
    my friend, the trouble is that the file is incorrectly read from address 0008A10 and bytes 08 are present. broken iprog makes such an error ....- maybe I'm wrong. right now i will try your file again. thanks
  14. #13
    Dec 2010
    Ukraine
    Few times i had same problem. Problem was on bad contact on CAN adapter. I solved problem with donor dumps. You should try different eeproms, don't need full.
  15. #14
    Oct 2017
    Ukraine
    Yes, I also processed these files
  16. #15
    Dec 2010
    Ukraine
    Same pass.
  17. The Following User Says Thank You to Zaveruha For This Useful Post:
    viiktor (31st March, 2020)
