So quick update I've bought a blank eeprom and managed to write the immo to this just wondering if I need to cut any wires ?
Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
Hi!
i have the same issue with 95080 eeprom at a sagem s2000 ecu from citroen saxo. I try to do immo off. Ktag writes untill 75%.
If i try to write back original eeprom file it writes 100%. Full back up, original flash write 100 no problem.
File with modified immo pin(not immo off) also writes 100%
Two immo off solutions i get error at 75%
Any suggestions ?
If i buy a new blank eeprom and solder it on the board do you thing that i will be able to write it with k tag?
sonikx (7th April, 2020)
Yes need to buy another blank eeprom had the last 1/4 of the eeprom is write protected so when you buy a repalctment it will write 100%
Hi just an update I programmed a new eeprom chip with your file you provided and car is working 100%
Also cut pins as stated above
speedy100 (20th April, 2020)
