Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    super jumbe's Avatar
    Dec 2008
    Livingstone
    Default Magic 4C chips help any one.
    Lads got an issue, friend of mine he is locksmith but he at the moment stuck in South Africa, I gave him 10 4C chips and he turn them to 4C Magic chip, I don’t have AVDI is there any other tools or a simple way to turn to magic 4C chips.
  2. The Following User Says Thank You to super jumbe For This Useful Post:
    Meat-Head (29th March, 2020)
  3. #2
    Dec 2008
    Livingstone
    Any one tried this tool, Is this tool any good for that job?
    4C 4D ID4D(60) chip for Magic Wand 4C 4D chip generator
  4. The Following User Says Thank You to super jumbe For This Useful Post:
  5. #3
    Dec 2010
    Nottingham
    you can do this with any tool capable of writing to a 4c chip . just write this to a 4c cloning chip and you have a magic chip , you only need one then clone from it
    7E 00 00 00 00 00 00 4C
    00 00 00 00 7E 00 00 01
  6. The Following 6 Users Say Thank You to rapidlocksmiths For This Useful Post:
    A22 (29th March, 2020), daniersms (29th March, 2020), key4man (30th March, 2020), Meat-Head (29th March, 2020), PocketHero (30th March, 2020), super jumbe (29th March, 2020)
  7. #4
    Meat-Head's Avatar
    Leech mode:-
    what is a magic chip please?
  8. #5
    Dec 2010
    Nottingham
    magic chip is the above basic logic that when written to a cloning chip like GTI , ck100, TPX1 , Z4C etc , will start and run alot of toyota , suzuki , mitsi vehicles but mainly older toyota 4c systems just as a coded key will with no issues , a master key for these if you like , doesnt work on ford if any one asks . been around for years and was a secret held by some but is now fairly common knowledge , saves removing ecu and eeprom , abrites added it to their software years ago as did the fvdi copy.
  9. The Following 5 Users Say Thank You to rapidlocksmiths For This Useful Post:
    A22 (29th March, 2020), daniersms (29th March, 2020), Meat-Head (29th March, 2020), PocketHero (30th March, 2020), super jumbe (29th March, 2020)
  10. #6
    Meat-Head's Avatar
    Leech mode:-
    so it a NON magic you clone customers orginal key, onto but a magic on you “insert key programmer - add key done”
  11. The Following 2 Users Say Thank You to Meat-Head For This Useful Post:
    super jumbe (29th March, 2020), wd bau (25th April, 2022)
  12. #7
    Dec 2008
    Livingstone
    Thank you rapid very much appreciated, look I had a last chip when I checked the reading it’s deferent from the one you have mentioned, but this chip could have been mixed when packing the reading says.
    7E 00 00 00 00 07 00 00
    Mind you could it be even possible both chips do the same work!
  13. The Following User Says Thank You to super jumbe For This Useful Post:
  14. #8
    Dec 2010
    Nottingham
    Quote Originally Posted by Meat-Head View Post
    Leech mode:-
    your not cloning customer key , if all keys lost , you write this logic to a 4c cloning chip like ck100 , gti , z4c , silca electronic heads keyline gk24 etc , and the car will start and run fine on the key with this chip , works on most older toyota 4c systems as well as some suzuki and mitsi 4c systems.
    magic no , just a master code for some old 4c systems , i keep one ready made on the van and just clone from it when needed.
  15. The Following 2 Users Say Thank You to rapidlocksmiths For This Useful Post:
    Meat-Head (30th March, 2020), super jumbe (30th March, 2020)
  16. #9
    Dec 2010
    Nottingham
    Quote Originally Posted by super jumbe View Post
    possible i guess , ive always used the logic listed , been using this for many years now before it was common knowledge and avdi included it , its been on so many forums since that very few still eeprom these old 4c models
  17. The Following 2 Users Say Thank You to rapidlocksmiths For This Useful Post:
  18. #10
    Meat-Head's Avatar
    Quote Originally Posted by rapidlocksmiths View Post
    For us leechers https://www.digital-kaos.co.uk/forum...-keys-solution
  19. The Following User Says Thank You to Meat-Head For This Useful Post:
  20. #11
    Dec 2008
    Livingstone
    Thanks every one.
  21. The Following User Says Thank You to super jumbe For This Useful Post:
    Meat-Head (31st March, 2020)
  22. #12
    Dec 2010
    Nottingham
    some machines will not write the full logic to the cloning chip , on these you just write below logic
    works same , when read on a reader the full logic will be shown , but above is adequate .
    make one , keep it on the van as a master and just clone from it every time you need it , or if you have abrites just make with this.
  23. The Following 3 Users Say Thank You to rapidlocksmiths For This Useful Post:
    just4upal (31st March, 2020), Meat-Head (31st March, 2020), super jumbe (1st April, 2020)
  24. #13
    Mar 2018
    UK
    What tool can write the full stream ?
    or I'm missng something?
  25. #14
    kemaster's Avatar
    Mar 2010
    BG
    Quote Originally Posted by Manta1600 View Post
    With Zed Bull you can manually input all data you need
  26. The Following User Says Thank You to kemaster For This Useful Post:
    Manta1600 (23rd April, 2022)
  27. #15
    ray-ray's Avatar
    Nov 2009
    No magic it’s tricking the ecu, the keylogic held in the chip is the logic for a unprogrammed slot. So a slot that has no value or transponder id is why the car is starting. Now there a key count for all keys programmed into the slot.
