Does any one know how to figure out what offset in the eeprom file that is controlling the fuel gauge? I know that offset 330 controls if the car is petrol or diesel and offset 320 controls the speedometer scale .
I have a cluster that are showing the fuel in reverse, so when it is full the gauge shows empty and reverse.
This is because the cluster is from the early b6 models and the fuel sender is from a newer one. Audi made the early models read reverse.
I am now looking to find a eeprom file from the same car but a newer model and write it to my cluster, which should make my fuel readings correct.
Or if anyone knows what offline number is descriping the fuel gauge, then let me know then i should be able to change it. (like offline 320, should be the one to corrct the speed).
So does anyone have a b6 3.0 petrol color cluster eeprom file they want to share with me, or know what line to modify to make the gauge work?
Thank you
HI, what car, manufacturing year, cluster nr, cluster manufacturing year?
Hi, post cluster eeprom, I will try to fix it.
audijoko (1st April, 2020)
Nobody knows anything about the offset line that descripes the fuel in the cluster? I am very willing to try to program myself, however im having a hard time finding out which offsets are equal to what functions in the cluster
Thank you
report ...............
thank you for the answer, I have been looking and trying the file in my car, unfortunally my fuel gauge is not working yet
I will keep on trying, and post the answer if i find it
