Results 1 to 7 of 7
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Default Error reading ME 7.5 ECU equiped with EVC KEY610
    Hi guys,
    I have here and ecu with EVC KEY610, i cannot read with ktag boot or obd kess. Also not with ioterminal.
    i removed the evc key adapter on the ecu (desoldered) also not possible to read.
    Anyone have an idea how to read? More information?
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
    mexanico1971's Avatar
    portugal
    The easy way , is the oldest way !
    Desolder and read
    My work is my life ART TECH GARAGE
    vitaliyl's Avatar
    Aug 2018
    Ukraine
    do you want to get the encrypted file?
    solder a regular chip and record the ori
    or
    raceshadow's Avatar
    Mar 2016
    Czech Republic
    Quote Originally Posted by sdtsedat View Post
    Hi guys,
    I had 2x ME7 with this KEY inside, and every time it was read with MPPS china (obd). But you can't write it back. I removed the adapter from the ECU and replaced it with a new 29F800. The Orig 28F800 has a changed checksum.
    IF I HELPED YOU, PRESS THANKS AND REPUTATION BUTTON!!!
    carmageddon's Avatar
    Italy
    Hi guys,
    hi
    very simple : desolder the adapter key610 from pcb and place it on eprom programmer and read it.
    Dec 2013
    the content of the momory inserted on the key adapter is encoded, you have to desolder key, then with external programmer you need to program original file in to flash memory. Then you will be able to work with this ecu normally. i have done a lot of such ecus. Always memory content was encoded, that's why there is decoding KEY.
    Italy
    is right but if you are courious about the encrypted job you can also read from adapter because the output data from encryption key are decoded, this allow at the ecu to work normally...and to the tuners to see the top secret mod (since 20 years i did this operation on many of this toys used from revo-apr-mtm-dimsport tuners and others).
    very funny
