The easy way , is the oldest way !
Desolder and read
Hi guys,
I have here and ecu with EVC KEY610, i cannot read with ktag boot or obd kess. Also not with ioterminal.
i removed the evc key adapter on the ecu (desoldered) also not possible to read.
Anyone have an idea how to read? More information?
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
Desolder and read
My work is my life ART TECH GARAGE
do you want to get the encrypted file?
solder a regular chip and record the ori
or
IF I HELPED YOU, PRESS THANKS AND REPUTATION BUTTON!!!
the content of the momory inserted on the key adapter is encoded, you have to desolder key, then with external programmer you need to program original file in to flash memory. Then you will be able to work with this ecu normally. i have done a lot of such ecus. Always memory content was encoded, that's why there is decoding KEY.
is right but if you are courious about the encrypted job you can also read from adapter because the output data from encryption key are decoded, this allow at the ecu to work normally...and to the tuners to see the top secret mod (since 20 years i did this operation on many of this toys used from revo-apr-mtm-dimsport tuners and others).
very funny
