Results 1 to 7 of 7
    mexanico1971's Avatar
    portugal
    Default Peugeot 508 RHX Hybrid mysterious Sart problem
    Hy Guys !
    Î have here one Peugeot 508 RHX Hybrid from 2013 , that suffer a rear impact !
    The car have be in the body repair shop , and one mechanic have try to fix some DTC"s and problems the car have.
    But after he try to erase the DTC"s in the power steering module , the car not start continuity.
    I also find the positive Born of the batt melted , by Some short circuit .
    Meat says maybe the problem is engine fuse box , but after read about this 3 days a lot , I found that reverse alternator , have the function of starter, and this is a problem that neither PSA dealer can fix, I read in several cases they give to the client other car.
    So I need all the schematics I can get
    This is the VIN VF38URHC8DL0118XX
    Thank in advance
    My work is my life ART TECH GARAGE
    Meat-Head's Avatar
    Can you list all the fault codes and which module.
    just a question is the fuel above minimum?
    Can you show photo of burnt cable?
    possable loose nut that has arced and damage fusebox
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    mexanico1971 (30th March, 2020)
    portugal
    Hi ! Yes
    in HCU1
    P1B69 - electric machine
    P1B66- electric traction machine
    in BSI 2010
    U1F00 00 event not stored
    B1606 81
    B1816 87
    U1F75 62
    B1818 93
    B132A 84
    TBMU
    P1A16
    HCU2 reverse alternator
    P1B66
    The short spot
    Meat-Head's Avatar
    That looks to me like Justy22 put his jump leads on backwards
    imagine it as a piece of metal hit by a welder
  6. The Following User Says Thank You to Meat-Head For This Useful Post:
    portugal
    Default Help please
    Does any one knows were is the rear wiper relay location ?
    Can any one get , wiring from BSM and BSI please !
    Thank"s in advance
    BRs
  8. #6
    Meat-Head's Avatar
    Start with when it runs leave it running check evrry fuse you can find
    start with use hand book to locate rear wiper fuse and start frombthere
  9. The Following User Says Thank You to Meat-Head For This Useful Post:
    mexanico1971 (1st April, 2020)
  10. #7
    portugal
    Update
    The owner bring me other inversor control module from 508 RHX, and now if Hi shift gears , the info in the dashboard change !
    In the past not doing that , but the module have different numbers numbers !
    Does any one swap these modules width one used ?
    thank"s in advance
    Best regards
  11. The Following User Says Thank You to mexanico1971 For This Useful Post:
    Meat-Head (5th May, 2020)
