Results 1 to 5 of 5
    Jun 2019
    Default kia sportage 95910-1f400 problems
    Hi all
    read out the chip on this as 9s12dg128 1l59w and also as a 9s12dt128 3l40k. I have previously posted on here and received 2 cleared files and tried both. but receive errors after programming saying the unit has an b6120 internal fault(only after reprogramming)
    programming back to the original clears the b1620 fault.
    What size should this readout be? on I get a readout of 800. if I increase the size to 1000 I still get data in the extra section? could this be something to do with it? or is there a procedure on reinstalling the ACU unit?
    Anybody able to tell me which size or help with this?
    Dec 2009
    Romania
    Need to read only eeprom 2Kb!What tool use?
    Jun 2019
    yes i read the original files out at 2kb. using carprog, Motorola mcu, hc12. just wanted to check I was reading the correct file size. reads/verifies/writes 100%.
    I cant think what could be wrong?
    Dec 2009
    Romania
    Yes is correct reading!
  5. The Following User Says Thank You to chiorbeq For This Useful Post:
    truckertommo (1st April, 2020)
  6. #5
    Jun 2019
    Chiorbeq Thank you for confirming it is a correct reading.
