Results 1 to 3 of 3
    Nov 2014
    Vojvodina
    Default Peugeot 206 1.4 16v IAW 6LP2 IMMO OFF
    Hello can someone do a immo off for this ecu?
    I have read the MPC 10F280
    It is IAW 6LP2.03
    Oct 2018
    i can only make you a virgin if you are interested and a pin code to give you,for the pin code we need eeprom from ecu
    Nov 2014
    Vojvodina
    I have the pin code from mpc. there is no eeprom in this ecu, everething is in MPC.
    Do you have a Virgin BSI file?
    I got this car with burned BSI, i got a second hand BSI and it would be good to make it a virgin and then program it on the car.
    The BSI is E02-00 9652474780 Siemens.
    EEPROM in it is 95160
    PIN code is >AR4V<
