Page 3 of 7 FirstFirst 1234567 LastLast
Results 31 to 45 of 92
  1. #31
    ray-ray's Avatar
    No coverage on X series jaguar on most China tool. Even the smart pro drop jaguar coverage.
  2. #32
    Nov 2013
    2014 Subaru Crosstrek, 4D ID82 chip (not smart key). Add key - ok, add remote - ok.
    Quote Originally Posted by ray-ray View Post
    Lonsdor showed "programming failed" at the end and new key didn't work at first. But somehow after switching keys back and forth couple times both keys started working.
    Other thing to note - all tools had only one option - "all keys lost, minimum 2 keys required", no "add key" option. Keep that in mind. It might be easier just to clone the chip if you have working key.
  3. #33
    Jan 2017
    USA ����
    I think last one i did was with skp900
    While everything else failed or didnt even have the option
  4. #34
    Nov 2013
    *2013 Ford Explorer (blade key) - second key programmed OK, 9 min wait.
    *2002 Lexus SC430. Guy came with just valet key. Did "all keys lost", took 5 sec, programmed new master key and valet key.
  5. #35
    ray-ray's Avatar
    I test a 2021 Ford Escape it pass but they won’t release it yet. Looks like the pandemic will work as a excuse. When the right time comes they will have a large release with a higher subscription to go with it. Just like how they up charge you because of the pandemic. There toyota emulator are not working..
  6. The Following User Says Thank You to ray-ray For This Useful Post:
    milehighlockdoc (11th September, 2020)
  7. #36
    lwood's Avatar
    city of angels
    thanks for the heads up ray ray.
    DON'T JUST SAY PRESS IT.....
  8. #37
    Jul 2016
    Does this do Ford parameter reset to current year and model?
  9. #38
    camelgd's Avatar
    Jan 2011
    South Illinois
    2017 Caddy CTS pulled pin ok with online connection but repeatedly received error message when trying to program proxy key.
  10. #39
    camelgd's Avatar
    Jan 2011
    South Illinois
    Just an addendum; APP phone app has one person saying he programmed this vehicle under chevy cruize, but would not go in under any caddy protocol. Any body there with Caddy proximity experience on 2017 up?
  11. #40
    Nov 2013
    2012 Acura TL (NA) - USED smart key added no problem. For some models it's hard to find information so here it is - key M3N5WY8145 is re-usable without unlocking.
  12. #41
    ray-ray's Avatar
    Ilco is mad everyone that bought the smart pro buy token in bulk sale and only use for emergency. There using token free tools like im608, Lonsdor AutoProPad etc.. to do all the work..
  13. The Following 2 Users Say Thank You to ray-ray For This Useful Post:
    michaeleschmidt (18th July, 2020), milehighlockdoc (21st July, 2020)
  14. #42
    Nov 2013
    2001 Audi A6 add key - correct PIN code was pulled from both dash and engine modules, programmed key OK, programmed remote OK.
  15. #43
    ray-ray's Avatar
    Keeps making money, no tokens
  16. #44
    autocheck's Avatar
    Feb 2014
    Zimbabwe
    RAY ray, which obd tool can you recommend , which can do mostly Nissan, Toyota , Jeep & landrover AKL smart and blade
    Sent from my SM-A605FN using Tapatalk
  17. #45
    ray-ray's Avatar
    For USA region the AutoProPad now mk3 is starting to sell in the Middle East. They are starting to add more things to beat Autel im608.
