Results 1 to 9 of 9
    GB
    Default Audi Q7 EZS and ECU Synchronize
    I need help syncing an audi q7 EZS and two new ecu.I made two ECUs by hand, with cs pin and vin data.The ECU no longer stores the immo DTC, but there is an entry in the EZS error log: the immobilizer data is not fitted in the ECU.The car runs for 3sec then stops.
    Synchronized EZS (A6, Q7) -ECU (edc16cp34) pair would also be a great help.
    GB
    Hello everyone ! I did the manual synchronization of the EZS and the ECU successfully :-) There is another problem under diagnostic address 01. After the sixth-seventh ignition is applied (after opening and closing the main relay), DTC P1640 control unit defective, eeprom error will set and cannot be cleared. I would need to change vin number in EZS ori (wauzzzxx87xx98202)
    Oct 2018
    hi change speed limit to 300 and immo off
    thnx button for help...pass pm
    ecu eeprom not good mileage.km 8km, how much to write to you mileage status ??
  4. The Following User Says Thank You to tothzsolt For This Useful Post:
    gaben8 (8th April, 2020)
    ricked's Avatar
    Apr 2016
    Europe
    did you also Synchronize power class in units ?
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by gaben8 View Post
    Oct 2018
    no, sync only via obd goes this way, these files I just changed the speed limit to 300km.h and immo off nothing more
    GB
    Quote Originally Posted by tothzsolt View Post
    I attach the two synchronized files.
    251664km is required.
    thanks !
    brend's Avatar
    Oct 2015
    Same where
    Audi q7 ecu synhro via obd2!?
    Explane how it's look?
  10. #9
    Oct 2018
    Errors
    The following errors occurred with your submission
    • gaben8 has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
