Panathaole (30th March, 2020)
If you want, I can check tomorrow if the pin out is the same as Renault...
The thanks button does not burn, you can press it without any risk !
Hi friend,
apparently there are 2 versions SID305 (TRICORE TC1762 NISSAN or TRICORE TC1766 DACIA RENAULT NISSAN).
Now I no longer own KTAG. I watched this at MAGICMOTORS. I don't think this is a problem with KTAG.
When you know the TRICORE version you have, tell me ...
BR.
Panathaole (31st March, 2020)
Hi, you have used this pinout ?
I found a discussion on another forum with the same nissan sid305 ecu and managed to read with KTAG 2.23 ...
I wake up the subject.
I have already made several renault sid305 without problem with ktag.
But for nissan, I find no sid305 ?????
Has anyone tried using renault drivers?
i uses ktag 2.23
---------- Post added at 8:10 p.m. ---------- Previous post was at 8:08 p.m. ----------
Hi I already made sid 305 nissan 2012 I go through protokol of the renault with ktag 2.23, it goes without problem.
REPLY:
Hi.
I confirm it goes impeccable
Thank you
Check solders and good power supply...
