Hi guys, I recently bought a Porsche Cayene v8, the car is a bit lazy to be a V8, but it sounds like the gods. You have installed a rear muffler suppressor, and I would love to see how it could make it explode on gear retentions and gear shifting, tried something, but I'm not sure if this works, I could check and fix it if the is not correct. archive? And if the file is correct, easily happy, based on experience working with VAG 1.8t engines, with which I can jump and hit hard between gear shifts and retentions, thanks in advance.
I attach the original and modified file, I only touch the base power maps, when I compare files it seems that something is modified, but the original file is searched from the network, possibly mine is modified, thanks in advance and regards
