hi mate,
Please enter this ISN in the ECU CAS3+ encrypted ISN : CE193E1E510534B147F88BCEAA44A35D. This is ECU ISN of the file you upladed CAS3+. After sync CAS with ECU with Autel or Launch. Hope it works for you
hi mate,
From a donor ECU that I want to match with the CAS
try to keep it humble
I mean autokeytech :-)
i got it using CGDI, I even have the cas isn but cannot change it
PM me again, have cleared my inbox....
And now your box is full
In about 1hour I can help you
i got it using CGDI, I even have the cas isn but cannot change it. i attached key password
Picture1 is bad cannot read CFG Page, better show Keyinformation from tango/hitag or vvdi2
write me in skype, this back and forth in the forum is shit.
you can find my skpye name in my profile
kamika
ori ISN from you cas3+ eeprom
VIN: WBAPG56030NM43371
KM: 0 km
ISN: 19D959C99162E371202F4BA97D84C48A
problem for change ISN Number ,Dump is coded no chang isn num...
can you explain how you figured out the ISN ?
Chriz123
I can of course, the BMW EXPLORER
Chriz123 (1st April, 2020)
