Test this file and report.
Thanks + Rep
Pass in PM.
I need some help with this file, i need popcorn at 4800RPM i already try but without sucess.
I try some help from one friend but i have this answer
"Hello,
I checked your SW version. On this file I can have a cut buti t don’t give POP-corn effect as older versions.
If you can downgrade ECU with an older software as 7xxx or 8xxx we can have Pop-corn."
if someone can help me the file it's attached.
Regards,
Jonas
Thanks + Rep
Pass in PM.
ankjay (27th November, 2020), Babos (21st August, 2020), CLRSPERFORMANCE (30th August, 2020), diags (1st April, 2020), djardo (1st September, 2020), Espinosa85 (14th May, 2021), ibrahimaktas14 (23rd June, 2022), jonas000 (1st April, 2020), parik (9th November, 2020), proel (10th October, 2021), smirnoff_rules (21st August, 2020), TuningInside83 (2nd April, 2020)
is it possible to please have the password for the file you sent him in the post?
Espinosa85 (12th May, 2021)
Ok. PRESS THANKS AND REPUTATION BUTTON and I will send password in PM.
PRESS THANKS AND REPUTATION BUTTON IF I AM HELPFUL.
dmtech (21st August, 2020)
Hello scima and I can easily make HardCut 4100rpm and Removed factory LC control ... for good worked Hardcut when the car is standing
CLRSPERFORMANCE (30th August, 2020), dmtech (21st August, 2020), Espinosa85 (12th May, 2021), Gokhan43 (19th November, 2020), ibrahimaktas14 (24th June, 2022)
I Press the thank's button
Can u send me in pm ? I dont permission for this file. thanks
Hola, pulso el bon de agradecimiento, gracias¡
Hola, pulse el boton de agradecimento. Saludos
