More info about car... year and options ,several diagrams for various equipment. The standard problem is always water in this module
I need pinout from a confort module from a Audi A6, 4B0 962 258 E.
this module has melted, and I have to find out the reason.
When I put a new one, it heat a lot.
Old...
WhatsApp Image 2020-04-01 at 11.52.03 (1).jpgWhatsApp Image 2020-04-01 at 11.52.04 (1).jpgWhatsApp Image 2020-04-01 at 11.52.05 (1).jpgWhatsApp Image 2020-04-01 at 11.52.04.jpg
Jeferson
Tecnocoli Car Repair
Hy try this.
jcoli (2nd April, 2020)
it's still not enough ... there is no single scheme for this module ... everything depends on the equipment of the car ... i.e. what lamps, type of body... if I remember correctly, the first plug that is closest to burning is responsible for powering the module and for the direction lights and external lighting. the rest of the cubes are internal lighting, central locking, rear door .... we need to do the pinout by gluing all diagrams together ...it's still not enough ... there is no single scheme for this module ... everything depends on the equipment of the car ... i.e. what lamps, type of body.if I remember correctly, the first plug that is closest to burning is responsible for powering the module and for the direction lights and external lighting. the rest of the cubes are internal lighting, central locking, rear door .... we need to do the pinout by gluing all diagrams together ...
Thanks,
I need the pinout for the first plug to find out the problem.
Jeferson
ttry this:
