Results 1 to 7 of 7
    May 2019
    São Paulo/Brazil
    Default Audi A6 Confort Module Pinout
    I need pinout from a confort module from a Audi A6, 4B0 962 258 E.
    this module has melted, and I have to find out the reason.
    When I put a new one, it heat a lot.
    Old...
    WhatsApp Image 2020-04-01 at 11.52.03 (1).jpgWhatsApp Image 2020-04-01 at 11.52.04 (1).jpgWhatsApp Image 2020-04-01 at 11.52.05 (1).jpgWhatsApp Image 2020-04-01 at 11.52.04.jpg
    Jeferson
    Tecnocoli Car Repair
    Sep 2012
    More info about car... year and options ,several diagrams for various equipment. The standard problem is always water in this module
    May 2019
    São Paulo/Brazil
    Quote Originally Posted by djnovy View Post
    A6 V6 2000, thanks
    Jeferson
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    Hy try this.
  5. The Following User Says Thank You to catalinosonesti For This Useful Post:
    jcoli (2nd April, 2020)
    Sep 2012
    it's still not enough ... there is no single scheme for this module ... everything depends on the equipment of the car ... i.e. what lamps, type of body... if I remember correctly, the first plug that is closest to burning is responsible for powering the module and for the direction lights and external lighting. the rest of the cubes are internal lighting, central locking, rear door .... we need to do the pinout by gluing all diagrams together ...it's still not enough ... there is no single scheme for this module ... everything depends on the equipment of the car ... i.e. what lamps, type of body.if I remember correctly, the first plug that is closest to burning is responsible for powering the module and for the direction lights and external lighting. the rest of the cubes are internal lighting, central locking, rear door .... we need to do the pinout by gluing all diagrams together ...
  7. The Following User Says Thank You to djnovy For This Useful Post:
  8. #6
    May 2019
    São Paulo/Brazil
    Thanks,
    I need the pinout for the first plug to find out the problem.
    Jeferson
  9. #7
    Sep 2012
    ttry this:
