Results 1 to 2 of 2
Hybrid View
    Mar 2019
    Default DIY EEprom Programmer for ST M95020 / m95080
    Ok so I made a DIY programmer for in circuit programming ST M95020 eeproms. I know, I know the minipro supports them but when done in circuit the minipro goes into over current protection so you have take them off. I also know OBD2 tools can program the cluster I do I just wanted to make the tool/share it. BTW if anyone knows how to do J1850 with an adruino please let me know! I did 2 versions of this project one is on an Uno and doesn't have the transistors to turn on and off power to the clip the other is with a nano and it turns off power to the clip when you aren't programming. Just some protection. I made the whole thing open source. I haven't updated the sketch yet to M95080 but I will probably do that in the next couple of weeks. I also haven't made an interface other than just using serial monitor... Im pretty lazy so that might never change. More than happy to answer questions. Any recommendations on slightly better software than tachosoft 20.1 its kind of shitty . I honestly don't do enough odometer correction to go out and buy the ODB2 tools.
    Gitub links:V1 https://github.com/garnerm91/st95020 V2: https://github.com/garnerm91/st95020/tree/master/V2
    Youtube instructions: V1 https://youtu.be/JH3pLX_Xkbk and V2 https://youtu.be/17RraCxJUcI
  2. The Following 2 Users Say Thank You to garnerm For This Useful Post:
    duckstar (5th May, 2020), Killer76 (3rd April, 2020)
  3. #2
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    nice project, years ago i made my own home made eeprom programmer to read 93cxx series,
    Nowadays I prefer to use Upa programmer, it's good and cheap, it costs less of 40 usd and a Magic Software with scripts better than tachoshit 23.1
    I use minipro only to read 29f200 or 29f400 flash memories in some ecus
  4. The Following User Says Thank You to jomberykaso For This Useful Post:
