Hi guys I need a good firmware for iprog ver77, I need to change mcu because while try to erase it , it burns , I need a any version ?
Many thanks
best regards
Many thanks
best regards
THANKS+REPUTATION
I am trying to figure out what is wrong for the firmware you have. What firmware are you using right now?
Hi body!
My iprog its killed, its go~~~~~ , SN777, software ver 77, I use with another sw and the devise blocked, so contact the seller and they try to unlock but something happend with mcu while we try to do that because after that the mcu gets hot everytime I conect it to usb port.
So I have another mcu, and just need a good firmware to try to flash it and put in the iprog+ before to buy a new one.
Many thanks
Best Regards
THANKS+REPUTATION
Have you tried to change the serial number? Hopefully it might work.
Else open it with a little of luck there might not be epoxy between the two pcb. There are lots of cases where the components have been successfully repaired. You will find a few thread on this forum where the members have guided which components need to be replaced
Hi , my question is the firmware if you dont have thats ok.
THANKS+REPUTATION
FIRMWARE
sn777 use to v55
Many thanks bro
Best Regards
THANKS+REPUTATION
