Page 1 of 3 123 LastLast
Results 1 to 15 of 35
    Feb 2018
    Default edc17cp14 limp mode
    hi im working with a cr140 engine i swapped. ecu number: 03l 906 019 hb cjaa 4817 hw:h15. engine is fitted with a hx30/35 holset turbo and the smart actuator and maf being deleted is putting it in limp mode. it is throwing a lot of codes. if anyone could help me out i would greatly appreciate it.
    heres a list of codes its throwing:
    p0045
    p0101 mass air
    p0405 egr
    p0486 egr
    p048e
    p0627
    p2017 intake flap
    p2100 throttle actuator
    p2101 throttle actuator
    p242a
    p246e
    p2564 turbo boost control sensor
    p2632
    golf110tdi's Avatar
    Apr 2016
    EU
    Test this file and report.
    Pass in PM.
  3. The Following User Says Thank You to golf110tdi For This Useful Post:
    BigTurboAlh (3rd April, 2020)
    Oct 2019
    Italia
    Quote Originally Posted by BigTurboAlh View Post
    p0045
    p0101 mass air
    p0405 egr
    p0486 egr
    p048e
    p0627
    p2017 intake flap
    p242a
    p246e
    p2632
    hello do you also have the fans on? let me know if you solve.
    Member YougNord's Avatar
    Apr 2020
    p0045
    p0101 mass air
    p0405 egr
    p0486 egr
    p048e
    p0627
    p2017 intake flap
    p242a
    p246e
    p2632
    p2564
    when you delete you will made limp mode a life
    dontt delete it
    try to repair car
    Feb 2018
    I’m running a big t3 single turbo. P2564 gotta be deleted
    Feb 2018
    I will test at lunch time thanks
    Apr 2020
    neeed repair all sensor from turbo
    when you delete you get turbo pressing low
    Feb 2018
    It’s a wastegated turbo. Not a vgt turbo. There’s nothing to repair.
  10. #9
    angelx431's Avatar
    Sep 2010
    BG Sofia Madrid
    p0045
    p0101 mass air
    p0405 egr
    p0486 egr
    p048e
    p0627
    p2017 intake flap
    p242a
    p246e
    p2632
    Repair the car normally!
    Gasoline in the blood!
  11. #10
    Feb 2018
    There is no repair it needs deleted
    I tried the file and still in limp mode
  12. #11
    Jun 2018
    Bulgariq
    p0045
    p0101 mass air
    p0405 egr
    p0486 egr
    p048e
    p0627
    p2017 intake flap
    p242a
    p246e
    p2632
    Thanks and Reputation =pass
    Pass-PM
    Test and Report
  13. The Following 2 Users Say Thank You to naskochipa For This Useful Post:
    BigTurboAlh (6th April, 2020), ECU KING (5th April, 2020)
  14. #12
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    contact me i can help you with this
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  15. The Following User Says Thank You to AVDigitale For This Useful Post:
    BigTurboAlh (4th April, 2020)
  16. #13
    Oct 2019
    Italia
    and a tested solution?
  17. #14
    speedy100's Avatar
    Athens
    p0045
    p0101 mass air
    p0405 egr
    p0486 egr
    p048e
    p0627
    p2017 intake flap
    p242a
    p246e
    p2632
    Do not waist Your time... This type of ECU expects data from the MAF sensor in order to figure out Air Quantity. Without it there is no way to run properly.
    Also You can not use any force induction system that will push more air in than the measuring capacity of the specific MAF.
    The only way to do this right is to use an aftermarket fully programmable ECU.
    Best Regards
  18. #15
    Feb 2018
    @naskochipa wouldn’t start with that file flashed back to stock and it starts
