What solution are you talking about? I’ve tested all the files above and nothing working yet. What could cause that file to make it not start?
Good thing you say success
BigTurboAlh (5th April, 2020)
You can remove the engine, like a flintstone.
Gasoline in the blood!
No success yet
[QUOTE=naskochipa;3838776]Good thing you say success[/QUOTE
no success yet
here in italy it was done ... eliminating the management of the turbo via electronic vgt.
Only brain and multimer.
BigTurboAlh (9th April, 2020), carbon7319 (9th April, 2020)
Here is file to test... no checksum!
The file is with DPF disabled and WITHOUT ANY diagnostic for ANYTHING!
I give you and a map pack for winOls 224... and there is one map 2x749...
Each line in this map is for some fault instance... you can make every line back to ory, untill start to have these faults, which are the real one at this moment and leave them as they are before make them ori... All of the others must be ori!
it is a huge work, but... without exact damos and free...
Good luck!
BigTurboAlh (10th April, 2020)
