Did you read ecu before ~~~~ it by writing file from other car?
If so flash again its original backup and car will start.
If not, read bdm flash and eeprom and upload here.
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
bidu20
uploading more and ori eeprom isn't just flash for immo off
Now read BDM Flash and EEprom, please immo off !
Don't forget the magic button !
immo off write eeprom and flash to ecu and car start ok
thnx button..pass pm
don't work, now I have the message "immobilizer active" on dash display. before i don't have that but car doesn't start and with VCDS is immobilizer defect.
write you flash flash mode and eeprom mode in ecu ?????? The solution is good checked for ok i don't know what could be the problem
WHAT IS TIPP EEPROM 95160 OR 95080 ???
FOR CALCULATE REPAIR CHECKSUM........... EEPROM
EEprom 95160
don't work, always "Immobilizer active", and car doesn't start. Any other ideas ?
I do not know why your good is not my solution immo off, if you had a car with me I would make.Did you type modi Flash and modi eeprom my desk I sent you ???
What tools do you use ???
I use KTAG and i can't select any mode, just write flash und eeprom with your files
Disconect engine ECU and switch ignition on ->>> you have the message "immobilizer active" on dash display???
bidu20 (6th April, 2020)
