Results 1 to 10 of 10
    Mar 2012
    Default AIRBAG F10 MAC 930ABD internal error help
    hello sensor numbers 65779239985 procesor MAC with internal error without crash, can anyone help? please help
    Oct 2016
    hi
    It seems that the reading is not correct.
    try again
    MAC72x1
    Mar 2012
    yes mate........
    Mar 2012
    try it with it
    Mar 2012
    this is with crash and 930abd internal error
    Mar 2012
    Someone has a solution pleas
    superjet's Avatar
    Aug 2018
    Quote Originally Posted by marcin22a View Post
    Write and recoding and clear errors,report.pass pm.
    good luck!
  8. The Following User Says Thank You to superjet For This Useful Post:
    marcin22a (4th April, 2020)
    Mar 2012
    Hello superjet ,I check back on Monday and let you know
  10. #9
    Mar 2012
    the internal error went out, I just had to encode it because it was without pedestrian protection, but it works thanks
  11. The Following User Says Thank You to marcin22a For This Useful Post:
    superjet (6th April, 2020)
  12. #10
    superjet's Avatar
    Aug 2018
    recoding it
