Results 1 to 10 of 10
    May 2009
    Default KEY MERCEDES QUESTION BGA NEC, NEED HELP
    there,I have to generate a new key for a 2010 mercedes b w245, the old key is bga like the one in the photo, it is possible to make a copy with the old nec model
    Many thhaks in te advace
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by morito View Post
    it is keyless key
    no posibility copy
  3. The Following User Says Thank You to rola1971 For This Useful Post:
    morito (4th April, 2020)
    p1et's Avatar
    Oct 2013
    If you ask if you can program NEC based key, then the answer is YES you can.
  5. The Following User Says Thank You to p1et For This Useful Post:
    morito (5th April, 2020)
  6. #4
    May 2009
    is not posible?? are you sure?
    this is my origina key
  7. #5
    Member agibalov's Avatar
    Jan 2016
    Rostov Don Russia
    OLD NEC KeyLess go dont work for car 2010+..... only start and radio
  8. The Following User Says Thank You to agibalov For This Useful Post:
  9. #6
    rola1971's Avatar
    Jun 2014
    Dublin
    it is standart mercedews key (in photo keyless go )
    copy no posibility you need read eis and calculaiting key
  10. The Following User Says Thank You to rola1971 For This Useful Post:
  11. #7
    May 2009
    hi
    is stadart key but whit nec bga chip, can I program new key whit old chip nec in new models 2010?
  12. #8
    May 2009
    [QUOTE=rola1971;3838172]it is standart mercedews key (in photo keyless go )
    copy no posibility you need read eis and calculaiting key[/QUOTE
    you're right but can I use this type of key?bought in aliexpress, reading eis and generating key?
  13. #9
    p1et's Avatar
    Oct 2013
    I already answered you but seems like you ignored my reply.
  14. The Following User Says Thank You to p1et For This Useful Post:
  15. #10
    May 2009
    ok many thanks for all
