What’s out there that’s good on new shape Focus etc don’t want AD tools
Thanks 👍🏻
Thanks 👍🏻
you can take a look at smok there is a module for ford and mazda
Jimmy07 (4th April, 2020)
Smok dont support Focus mk4 and new Fiesta at this stage. Is quite good on 2017- Mondeo mk5 platform and 2017- Mazda.
abrites and AD are the 2 players on the latest fiesta and focus at present and ad easily edges it at present , only a matter of time before others get it of course , but if not wanting these then just have to be patient its only a matter of time. you could get ids and online subscription but this can work out dearer long term dependent on volume.
I have one of these
FORD/MAZDA Key Programming Device via OBD II
The FORD device will program all FORD cars from 2005 to 2019 year via OBD II and will do the key programming for 10 to 90 seconds without any need of internet connection. You will only need to have the correct key/transponder for the present vehicle, turn ignition on and then plug in the device and wait for 10 to 90 seconds and the key/transponder will be programmed.
Not cheep, got mine from vag-info.com
Thanks for replies 👍🏻
Hi Rapid - Hope you are fine now
Are you tried TDB1000 Ford on Ford Transit ID49 2019 with JU5T ?
I had 3 cars and every time fail
Transit - AKL with alarm - Failed afetr 2 days waiting bip bip
Transit Connect - add key - failed to add key
Transit Custom - AKL Smart key - failed
On their site they advert that can program this model
i dont have tdb1000 , so not tried it no , i have its coverage on a number of machines already so isnt on my radar at present
Manta1600 (6th April, 2020)
But I tought with latest Ford if alarm sounding keys cannot be added and they require a new bcm does this not applies to all Transit mk8 connect and new fords has anybody been able to add keys on akl on these models.
Have you looked into Ford truecode!!!
truecode is good but will not do the new focus and the 2017 on fiesta models
super jumbe (7th April, 2020)
