Results 1 to 8 of 8
Thread: Audi Q7 Airbag
    Default Audi Q7 Airbag
    Hello, can someone help me clear the crash?
    Audi Q7
    4M0959655E with 95128
    Ukraine
    You clear file.
    Thanks Vladimir
    I try to clear the fault codes with VCDS but not possible ???
    I try with orig crash dump and your clear dump too and the problem is the same....
    Someone has experience with this???
    Ukraine
    Dump tested 100%. In this unit there is a hardware problem with BOSCH drivers 40138, if you have B2000 DTC, replace SRS unit.
    Isnt there a way to erase B2000 after crash??
    Yes your dump is ok, i replaced both bosch driver and the unit work fine....
    Top Poster tec.guilherme's Avatar
    Brasil
    Hi Friend I have Problem same ECU Part Number 4M0959655E - With 95128 Inside.
    Ukraine
    Try and report.
