Results 1 to 7 of 7
    Germany
    Default VW Radio Code RCD 200 7H0 035 152 H
    Hello i need the radio code for my VW Radio The serial number is: VWZ4Z4G7160645
    Thank you in advance and
    Kind Regards.
  2. The Following User Says Thank You to mm04kk For This Useful Post:
    razvanrms (4th April, 2020)
  3. #2
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    Quote Originally Posted by mm04kk View Post
    Kind Regards.
    hy ,read this
    code is stored on EEPROM 24C08 ST
    wbr
  4. The Following User Says Thank You to catalinosonesti For This Useful Post:
    mm04kk (4th April, 2020)
  5. #3
    Germany
    Hello
    can i delete the code funktion on the eeprom because it always says safe
  6. #4
    Mar 2019
    east nord pole
    Leave it cca 1 hour power on ,open , then safe goes
    or read eeprom put here
    wbr
  7. The Following User Says Thank You to catalinosonesti For This Useful Post:
  8. #5
    Germany
    or i read it now and put it here than you can delete the pin funktion on it
  9. #6
    Germany
    thank you very much my friend i have found the code in the eeprom dump and waited for one hour now it works thank you very much.
  10. #7
    aissa09's Avatar
    Blida Algeria
    try 1076 .....
    Best regards aissa
    AISSA SERVICE ELECTRONIQUE
    BLIDA car radio decode
  11. The Following 6 Users Say Thank You to aissa09 For This Useful Post:
    Albert G (5th April, 2020), catalinosonesti (5th April, 2020), masterskay62 (5th April, 2020), nigrou (5th April, 2020), sonices (5th April, 2020), yahia1908 (5th April, 2020)
