Numbers srs unit ?
Hey guys i have a 2018 audi a5 sportback. Vehicle has airbag light on lots of faults stored in airbag module.All fault for airbags are passive as they have been changed. I have static fault for airbag control module B2000 cntrol module faulty. Im guessing crash data needs to be erased?? Can anyone tell me which chip or how I can go about doing this?? I have eeprom readers and some software.
Numbers srs unit ?
Best regards.
Dragon
8W0959655G SOFTWARE VERSION 0107
Desolder eeprom 95128 and read, upload file , I will fix ok if your srs unit not faulty ...
Best regards.
Dragon
I just got the module can it be done??
Upload file from eeprom ...
Best regards.
Dragon
Read H128 eeprom as S95128. I think should be ok. Please let me know. File attached.
szogun0 (5th May, 2020)
File look ok readed ...
Best regards.
Dragon
Can I flash this file back?? Not sure if reading as S95128 is acceptable?? Also is there any risk of having a corrupt flash when connecting airbag module??
Ok works perfect. Thank you!!
auto80 (11th April, 2020)
Hi, have same problem, B2000 and crash. Can anybody help?
Try this and report back.
Thanks for reply, but B2000 and U11188 - data set missing, errors in control unit.
