NEED TESTED SOLUTION FOR KIA TELLURIDE 2020 95910-S9000
Results 1 to 4 of 4
    May 2017
    USA
    Default NEED TESTED SOLUTION FOR KIA TELLURIDE 2020 95910-S9000
    NEED TESTED SOLUTION FOR KIA TELLURIDE 2020 95910-S9000 WITH TC 233.
    POST EPROM AND FLASH FILE
    THANSK
    SadCriss's Avatar
    At the Garage
    What is the original file? you have 2 version of eeprom
    If It helps you try push the: Thanks and REP
    I do the same each time it helps.
    May 2017
    USA
    are thge same file
    SadCriss's Avatar
    At the Garage
    If you compare file is diferent....
