Results 1 to 11 of 11
    Jul 2018
    Default Nissan Altima 2013 98820-3TA0C crash clear
    hello,
    help me please to clear crash from dump Nissan Altima 2013 98820-3TA0C SRS
    read it by UPA original
    thanks!
    May 2017
    USA
    Default HERE YOUR FILE TEST AND REPORT
    here tested solution pass pv
  3. The Following User Says Thank You to yluis515 For This Useful Post:
    subzverb (4th April, 2020)
    Jul 2018
    Quote Originally Posted by yluis515 View Post
    your dump is from another car as I understand. should it work ?
    May 2017
    USA
    use your original file or my no problems. same pass
  6. The Following User Says Thank You to yluis515 For This Useful Post:
  7. #5
    Jul 2018
    after writing last cleared file - new DTC appeared: B1414 and B1406 - cleared dump is wrong.
    maybe someone have other solution ?
  8. #6
    Dec 2009
    Ukraine
    Try this file.
  9. The Following User Says Thank You to Vladimir.zheurov For This Useful Post:
    subzverb (5th April, 2020)
  10. #7
    Jun 2018
    Ukraine
    Default Altima
    Hi.
    Test and report.
    Regards.
  11. The Following User Says Thank You to ElderDM For This Useful Post:
  12. #8
    May 2017
    USA
    Default Use my clear file is a tested file 100%
  13. The Following User Says Thank You to yluis515 For This Useful Post:
  14. #9
    Jul 2018
    yluis515 and ElderDM files are correct, thanks guys.
    I made mistake at the beginning, so the module was partially not working, now solved.
  15. #10
    Sep 2016
    Quote Originally Posted by subzverb View Post
    What is a password to these dumps, guys? I've tried "pv" but it is wrong HELP!
  16. #11
    Sep 2016
