odis online you can adopt the dash
Hello guys. I am curious if there is a way to virginize a used cluster for 2012 audi a8l. Original cluster is randomly flashing not displaying anything on screen and no gauges work. Customer purchased good used cluster. However cannot adapt as test plan says cluster is not new,will not let me adapt. Is there a way to virginize this cluster for adaption??Or way to set to new mode??
Tried Odis. Using factory scanner Test plan says cluster is not new,unable to adapt. Then ends test plan. Maybe in USA guidelines are different??
you need to do online component protection
Csc Performance.
Performance tuning file service.
Hey guys I was able to adapt the cluster but the mileage does not match. Any tool that will do this dash?? I don’t think Odis has capability to adjust
what about digiprog?? reading s95320 on bench? save dump edit to zero then flash back and see if mileage can be changed???
Anyone know where mileage is located on s95320???
AudiS4 (11th April, 2020)
enigma,dp4 make this without any problem
