Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 81
  1. #31
    matej505's Avatar
    Dec 2019
    Warszawa Polska
    Unfortunately, the same error does not work, it seems to me that I will have to make artificial ignition and then the hfm will pair. I noticed that without ignition you can not even enter the ECM ...
  2. #32
    Dec 2016
    Quote Originally Posted by matej505 View Post
    No need ignition on Renault cars to program card , HFM ou UCH .
    I think this tool not able to add card for 2016+ CLIO 4 , contact Poland patriot to help you with R.E.T ( https://www.emulatorshop.com/devices...coding-tool-en ) , or go to an Renault dealer .
  3. #33
    matej505's Avatar
    Dec 2019
    Warszawa Polska
    I will do exactly that, thank you so much for your help. In my example, someone reading these posts would be careful when adding keys with unverified tools.
  4. #34
    Dec 2016
    Renault cars using card after 2011 have secured pairing = Seed-Key Security
    Romanian Gabigafu don't finish job with is tool , R.E.T is the only way , i never use this tool for Clio 4 , i use R.E.T in same situation with success .
  5. The Following User Says Thank You to TERMINATOR1000 For This Useful Post:
    godfathertre (4th September, 2020)
  6. #35
    Aug 2019
    Bucharest Romania
    Quote Originally Posted by TERMINATOR1000 View Post
    Are you sure?
    Gabi's words: "O noua versiune, 1.86, care permite citirea codului pin pentru HFM Clio 4 si Captur 2016+. Este nevoie de o cartela valida pentru a invata HFM-ul pentru ca procedura il virginizeaza. S-a adaugat si o baza de date noua din decembrie 2019."
    Google Translate: "A new version, 1.86, which allows reading the pin code for HFM Clio 4 and Captur 2016+. You need a valid card to learn HFM because the procedure virginizes it. A new database from December 2019 has been added."
    The same for version 1.84:
    "O noua versiune 1.84. S-a adaugat programare cartele pentru Clio4 (2012-2015), de asemenea o noua baza de date din iulie 2019, precum si suport pentru ObdLink MX+."
    "A new version 1.84. Added programming cards for Clio4 (2012-2015), as well as a new database from July 2019, as well as support for ObdLink MX +."
    Maybe somewhere is a little trick. Renolink isn't intuitive.
  7. #36
    Dec 2016
    test & report !
    if you are smartest than us , lot of happy user all around the world , but in this case the car is dead if you can't learn HFM before learn cards
    HFM learning in protected mode don't exist simply because Chinese theft the tool before
    do no use this tool for 2016+ Clio 4
  8. The Following 3 Users Say Thank You to TERMINATOR1000 For This Useful Post:
    amazig (5th September, 2020), andreia67 (5th September, 2020), PierreTheron (30th September, 2020)
  9. #37
    Dec 2015
    Rafah, Palestine
    do no use this tool for 2016+ Clio 4 [/SIZE]
    Is it safe for clio 2015?
  10. #38
    Aug 2019
    Bucharest Romania
    Quote Originally Posted by just4upal View Post
    I am very curious too, wait for TERMINATOR 1000 to answer.
  11. #39
    matej505's Avatar
    Dec 2019
    Warszawa Polska
    I warn everyone not to use the enable read pin code option because it clears the immobilizer code !!!!!! ISK and PIN can easily read but.After this operation The car, despite a working card, does not recognize it !!!!!!!!!!! On my example, I have to buy RET for 1000 EUR and pair the HFM with the system.
  12. The Following User Says Thank You to matej505 For This Useful Post:
    PierreTheron (10th September, 2020)
  13. #40
    Dec 2016
    Yes if you dont push button "enable read pin code"
    just read PIN code > TEST PRESENCE OF CARD ( for only new cards) > NO CARD IN READER >START LEARNING > insert car 1 > LEARN CARD > insert card 2 > LEARN CARD > insert card 3 > LEARN CARD > insert card 4 > LEARN CARD > VALIDATE
    600€
  14. The Following 9 Users Say Thank You to TERMINATOR1000 For This Useful Post:
    A22 (1st October, 2020), andreia67 (5th September, 2020), danielif (29th September, 2020), godfathertre (5th September, 2020), just4upal (6th September, 2020), Keyblade (5th September, 2020), newone (5th September, 2020), p1et (3rd October, 2020), PierreTheron (11th September, 2020)
  15. #41
    matej505's Avatar
    Dec 2019
    Warszawa Polska
    Hello renolink damaged the content of HFM and most importantly ISK and PIN are incorrectly read by him .... I'll try to read the ECM on the V50.1 Valeo table.
    New HFM content works fine but doesn't accept code.
  16. The Following User Says Thank You to matej505 For This Useful Post:
    swingman26 (14th October, 2020)
  17. #42
    Jul 2011
    Iasi, Romania
    In HFM xml you show in the video there is a button named "APC ON by Diag"
    This means Ignition ON by Diag (in French APC = apres contact)
    Please feedback.
  18. #43
    matej505's Avatar
    Dec 2019
    Warszawa Polska
    After pressing this button, you hear the transmitter in HFM and the meter appears to tell you to turn the steering wheel and press start, after doing it, nothing happens.
  19. #44
    Jul 2011
    Iasi, Romania
    So it looks that ignition is switched ON successfully.
    According to my knowledge a virgin HFM should be correctly coded on the car with a valid card at first ingnition ON.
    Was your HFM still virgin at that time? Or it was manipulated before by dump or something?
    I understand that in your case Renolink reads the wrong ISK and PIN code?
    You can verify your pin code by writing it in the "after sales code" field and then press "enter after sales mode" button. Of code is good status next to after sales mode will be yes.
  20. #45
    PierreTheron's Avatar
    Centurion,South Africa
    This is for clio4 up till 2015 m8 . after 2015 we are still ~f~~~ed ???
  21. The Following User Says Thank You to PierreTheron For This Useful Post:
    p1et (30th September, 2020)
