Page 4 of 6 FirstFirst 123456 LastLast
Results 46 to 60 of 82
  1. #46
    Aug 2015
    Quote Originally Posted by PierreTheron View Post
    This is for clio4 up till 2015 m8 . after 2015 we are still ~f~~~ed ???
    what are experience on exactly 2015 year?
  2. #47
    Jan 2020
    UK
    I have bought original renolink 1.87
    Does anyone here know and can tell me exact procedure for all keys lost?
    Renault Scenic 2007
    BTW how to switch to English in the soft.
    Thanks in advance
  3. #48
    Aug 2015
    Quote Originally Posted by Plopek View Post
    Renault Scenic 2007
    Thanks in advance
    Extra > Keys > Scenic 2 > Read Pin > Connect > Start Learning > Learn key card > Validate
  4. The Following User Says Thank You to dtip For This Useful Post:
    Plopek (9th October, 2020)
  5. #49
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    so is possible with 2014 Clio 4 new chinese card?
  6. #50
    Aug 2015
    Quote Originally Posted by teerak2uk View Post
    yes no problem, i did 2015. Card was aftermarket from local dealer part number - 285971998R - COG-VIST1054-05
  7. #51
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by dtip View Post
    What procedure did you use as have a car with no key cards
  8. #52
    Aug 2015
    i had a working card but i am sure it will work with all keys lost as pin is read with no ignition.... just do like this
    card in - card out (no ignition) > Keys > clio4 > Read Pin > Connect > Card in and Test presence (if new card) > Start Learning > Learn key card > Check box and Validate
    whatever you do just don't press enable pin code read which will virginise HFM and you will brick it, it is not neccesery for 2014 year
  9. The Following User Says Thank You to dtip For This Useful Post:
    teerak2uk (13th October, 2020)
  10. #53
    swingman26's Avatar
    france 26
    Yesterday a friend who have renolink, tried to add card with it. Enable read pin 2015+, virginse hfm... after that card not recognised by car.
    I connect renault ecu tool, i read pin and isk and compare with renolink. Pin and isk are different.
    I learn hfm with renault ecu tool and isk readed from RET. Works perfect.
    Renolink not work with 2015+
  11. The Following 6 Users Say Thank You to swingman26 For This Useful Post:
    godfathertre (14th October, 2020), p1et (14th October, 2020), PierreTheron (25th May, 2021), Raould (5th May, 2025), teerak2uk (17th October, 2020), TERMINATOR1000 (14th October, 2020)
  12. #54
    Dec 2016
    Quote Originally Posted by swingman26 View Post
    " il a eu de la chance ton ami ", never use this tool for 2016+ cars , other users have corrupted definitely her HFM .
  13. The Following User Says Thank You to TERMINATOR1000 For This Useful Post:
  14. #55
    Aug 2019
    Bucharest Romania
    Terminator 1000 is right. Never use button " Enable PIN Reading". End of 2015, 2016 and newer you can't read pin with Renolink. For 2015 if you can read pin it's because is from the first part from the year, same with 2012-2014.
  15. The Following User Says Thank You to andreia67 For This Useful Post:
  16. #56
    matej505's Avatar
    Dec 2019
    Warszawa Polska
    If someone pressed the PIN code reading button after 2016, I provide the content from the working HFM module. Just do Virgin ret and teach with a new ISK code or PIN obtained by other means, because renolink damages the HFM content and does not read ISK and PIN correctly despite the fact that it shows some nonsense.
  17. The Following 8 Users Say Thank You to matej505 For This Useful Post:
    andreia67 (20th October, 2020), dtip (17th October, 2020), estwood68 (27th February, 2022), morfej (21st September, 2021), rafal (17th October, 2020), teerak2uk (17th October, 2020), TERMINATOR1000 (17th October, 2020), uzet (20th August, 2021)
  18. #57
    Aug 2015
    So you managed to fix your problem? how did you get pin, from ecu?
  19. #58
    Dec 2016
    He use another tool , or unplug battery for 2 minutes .... Renolink kill HFM & provide fake ISK / PIN code
  20. The Following 2 Users Say Thank You to TERMINATOR1000 For This Useful Post:
    rafal (17th October, 2020), Raould (5th May, 2025)
  21. #59
    p1et's Avatar
    Oct 2013
    The good thing is after Renolink virginize HFM and provide wrong PIN & ISK, you are able to recover car by using R.E.T because it will read correct PIN when HFM is already virginized. Exactly like in post #53.
    So you're not fcked up after using Renolink enable PIN read function. You would be fcked up if it damages HFM content in that matter, than R.E.T would not read correct PIN and ISK afterwards and only way would be dealership.
  22. The Following User Says Thank You to p1et For This Useful Post:
    PierreTheron (6th May, 2021)
  23. #60
    matej505's Avatar
    Dec 2019
    Warszawa Polska
    In my case, ret did not solve the problem. Step 5 error ......... and information about disconnecting the battery for a minute ..... and so on and on. I fixed the content of HFM data flash and code flash from another module I took the car to a Renault specialist and he says he fixed it with a clip
  24. The Following 3 Users Say Thank You to matej505 For This Useful Post:
    morfej (21st September, 2021), p1et (17th October, 2020), PierreTheron (6th May, 2021)
