Page 6 of 6 FirstFirst 123456
Results 76 to 82 of 82
  1. #76
    Dec 2016
    Quote Originally Posted by dtip View Post
    No true, as i posted before i did 2015 (HFM before 2015) without any problem and many others...
    no support all Clio 4 cars ( under 2015 of course ) , an 50% tool , not for professional use , just an good DIY tool
  2. #77
    May 2011
    Quote Originally Posted by TERMINATOR1000 View Post
    just read PIN code > TEST PRESENCE OF CARD ( for only new cards) > NO CARD IN READER >START LEARNING > insert car 1 > LEARN CARD > insert card 2 > LEARN CARD > insert card 3 > LEARN CARD > insert card 4 > LEARN CARD > VALIDATE
    Ive an Renault Megane 3 2012 with only one working key card
    Can someome tell me the correct procedure?
    I dont know if i need to click in test presence of card because ive one key card working.
    Note: I bought an new key on alliexpress
  3. #78
    Apr 2021
    I have read this thread. But don't understand how in correct way a learn HFM module from another car, with renolink tool. I have a virgine dump and can flash it. But I don't know how to learn and put inside HFM module a correct PIN & ISK & VIN (which I know), from a patience car. Which also have a two signed key ignition. What is the procedure ? I'm scare to press "enable red pin", because don't want damage immo or uch. Donor car: CLIO4 2015, patience car: Russian duster with HFM 2015.
  4. #79
    Jul 2015
    Quote Originally Posted by fcastro1988 View Post
    now I managed to learn the key, but the other one stops working. whenever i put one to work the other for, can you tell me the steps?
    1 read pin
    2 coonnect
    3 start learning
    4 ???
    5 ???
    6 ???
    sorry and thanks. is that there is no toturial on the internet
    card is new .
    the way it works is
    on 4 button keycards when learn for any model reno is a way in all tools is same process
    when learn a new keycard use this first to learn and use existing card 2nd and then both program in
    when doing AKL do first 1 card and then run process again and use the new unprogrammed card first this time and the ones already programmed as second car
    https://lock50.co.uk/tagpro/lock50-t...gramming-tool/
  5. #80
    Jul 2015
    https://lock50.co.uk/blog/renault-clio-captur-precoding-dealer-keycard-with-known-pin-code/
    Here have a step by step how to guide to do AKL on clio or captur phase 2
    process involves hfm learning and have step by step images of how to
  6. #81
    PierreTheron's Avatar
    Centurion,South Africa
    In my case i had clio4 that had low batter voltage and lost keycard then....
    Only senseble way to recover was with renault online to fix all and it worked 100
  7. #82
    Jan 2009
    Hi just managed to program new blank key card from aliex 13£ and Renolink 2.10 18£ on Renault Captur 2014, but I need to thank everyone involved in thread.
    Do not press Enable ISK readlingg
    1.Read pin
    2. Connect
    3.Test presence
    4.Start learning
    5. Lear key
    6 .Validate
    For more than one key reapet 4 and 5.
    https://www.youtube.com/watch?v=o_5cvPtp_Iw not my video but it helped me.
  8. The Following User Says Thank You to gwawryszuk For This Useful Post:
    Raould (Yesterday)
