I have read this thread. But don't understand how in correct way a learn HFM module from another car, with renolink tool. I have a virgine dump and can flash it. But I don't know how to learn and put inside HFM module a correct PIN & ISK & VIN (which I know), from a patience car. Which also have a two signed key ignition. What is the procedure ? I'm scare to press "enable red pin", because don't want damage immo or uch. Donor car: CLIO4 2015, patience car: Russian duster with HFM 2015.
the way it works is
on 4 button keycards when learn for any model reno is a way in all tools is same process
when learn a new keycard use this first to learn and use existing card 2nd and then both program in
when doing AKL do first 1 card and then run process again and use the new unprogrammed card first this time and the ones already programmed as second car
https://lock50.co.uk/tagpro/lock50-t...gramming-tool/
https://lock50.co.uk/blog/renault-clio-captur-precoding-dealer-keycard-with-known-pin-code/
Here have a step by step how to guide to do AKL on clio or captur phase 2
process involves hfm learning and have step by step images of how to
In my case i had clio4 that had low batter voltage and lost keycard then....
Only senseble way to recover was with renault online to fix all and it worked 100
Hi just managed to program new blank key card from aliex 13£ and Renolink 2.10 18£ on Renault Captur 2014, but I need to thank everyone involved in thread.
Do not press Enable ISK readlingg
1.Read pin
2. Connect
3.Test presence
4.Start learning
5. Lear key
6 .Validate
For more than one key reapet 4 and 5.
https://www.youtube.com/watch?v=o_5cvPtp_Iw not my video but it helped me.
Raould (5th May, 2025)
