Hello, i need my radio code for an Volksagen BNO 881 Radio
dump is in attachment
Thank you in advance and kind regards
bogege (6th April, 2020), masterskay62 (5th April, 2020), mm04kk (5th April, 2020)
sorry 0420 is wrong
if you dont get the code do you can make it off in dump that i can write it
maybe 0458 !??
0458 is also wrong
try code 1810
It is also possible
hello thank you all very much i have tried the first twoo codes and they dont work then i have writed this dump which i found on google to the radio now the radio is without code.
It works fine now.
Thank you all for your help
Why, will the radio makes problem after some time? I dont know i try it first time now. The radio works it comes on directly and dont need code and works everything. Do you have problem before with this file?
Kind regards
Try to keep the radio without power for longer. I never tried this file because i didn't need it
If you don't like it * close your eyes
--- Geros dienos ! ---
Thank you very much, if he needs code after some time i will write the original file back and try the codes that are posted here.
I also found a file where the code is 1574 if the codes from here dont work i will write this file and try this code
