Results 1 to 6 of 6
    Jun 2010
    Default Iveco Daily 3.0 DPF
    Hello!
    Can anybody help me?I need a DPF Off file for Iceco Daily 3.0 EDC17CP52 ecu.
    Bosch part number: 0281020149
    Thank's!
    Jun 2018
    Bulgariq
    Quote Originally Posted by PiciGSM View Post
    Hello!
    Thank's!
    Thanks and Reputataion= Pass
    Pass-PM
    Test and Report
  3. The Following 2 Users Say Thank You to naskochipa For This Useful Post:
    francog (8th April, 2020), PiciGSM (6th April, 2020)
    Jun 2010
    Quote Originally Posted by naskochipa View Post
    Pass-PM
    Test and Report
    Thank's Naskochipa!Your off file is good but the MIL is on and the P2453 dtc is come.
    Is there a solution?
    Sep 2016
    Poland
    in this car must cut dtc + limp from temp sensor, dpf pressure, good choice is emulated temp sensor. This software remove only switch witch not worked perfectly off course. And On first step when car have 70% or more suite dpf must be reset on stock file. Regards
    FILE SERVICE
  6. The Following User Says Thank You to voltechcar For This Useful Post:
    PiciGSM (15th April, 2020)
  7. #5
    Jun 2018
    Bulgariq
    TEST AND REPORT
  8. The Following User Says Thank You to naskochipa For This Useful Post:
  9. #6
    Sep 2016
    Poland
    he cut dpf mechanical and car back to p2002, cut to him all from dpf.
    FILE SERVICE
