doesn't mvp do it?
Anyway start with posting glovebox stiker to get code
Hi on job now 04 micra
Akl
Lonsdor won't activate steering lock
Autel doesn't have option either
How to get ign on to program new key ?
I have glovebox Sticker
Tools owned -
AD100 PRO, Lonsdor, FVDI 18, FVDI 20, VVDI PROG, VVDI2, VVDI MB
CGDI BMW, SuperVag, Renault ECU tool, OBDstar X300 DP Plus, AUTEL im508
VVDI Mini Keytool, KeyDIY KDX2, SBB, ACDP CAS/KVM
Opcom, VCDS pro, Diagbox, Multiecuscan, Forscan, JLR SDD
doesn't mvp do it?
On ad100 you simply turn the hazard lights on, when prompted, and most importantly, make sure the key is inserted in the right way.in the twist ignition,
Micra k12 intelligent key nothing but agro I gave up last job..
Note:All information given is to be used for educational purposes only and should not be taken seriously.
I did too today.
Nothing would do steering lock off to turn on ign
Most nissan lonsdor easy turns steering lock off.
Even done same intelli key on qashqai 07 the other day akl
K12 seems a bit of a mare with intelli key akl
Tools owned -
Even with smartpro can be issue but managed
I'm 99% sure skp900 can do steering lock on these,
Sent from my SM-A505FN using Tapatalk
