No keycode on the ignition but wafer are stamp with reverse number 1=4, 2=3, 3=2, 4=1 in the USA the passengers door has code if there a key hole.
Yaris 2007 is there key code on ignition lock if I dismantle yes or no, any help very much appreciated.
super jumbe (7th April, 2020)
it is not the best job to do with lishi, I have done a week ago yaris 2012 and I had to waste about 8 blades to do it right one ;-/
super jumbe (8th April, 2020)
9 cuts total, last cut nearest to the tip is always a 2.
I would give it a go with lishi decoder, and impressioning might work.
These locks, so far i remember, they cilinder core is pulled in whilst turning ignition on.
Before using a lishi, or impressioning make sure it does or doesnt.
Is there no door lock, they are open on the bottom, and the shims are vissible.
super jumbe (9th April, 2020)
T30 torx
Remove door lock
Read code
Cut key
Money?
lkjubaking (8th April, 2020), super jumbe (9th April, 2020)
No codes on drivers door lock, ended ordering lishi TOY47 will have a go, you got to start some were!!!
If its TR47 and door is already unlocked then the door lock is extremely easy to disassemble and sight read or view stamps wafers. Probably just as quick (and more reliable) then lishi honestly.
nate13853 (11th April, 2020), super jumbe (9th April, 2020)
