here you go
try and report
pass pm
here you go
try and report
pass pm
HELP == thanks + reputation
not work friend
now have B0100-49 internal errors,
only one error
Hi Petar, check this, if not work I will prepare better vitamine ...
Best regards.
Dragon
PETAR (10th April, 2020)
not work the some error
B0100-49 ECU INTERNALERRORS-internal electrinic failuture
PETAR (13th April, 2020)
hi test and report thanks
This should work ok ...
Best regards.
Dragon
not work
now have 12 errors
m8, replace the module
Cheers
try change old eeprom on new eeprom 95640
eefresh (20th April, 2020)
Hi ...solved problem??
try this file. yours is identical 52029749 bosch 0285013184 that I have repaired.
PW in PM
..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
PETAR (21st April, 2020)
