    m1405's Avatar
    Dec 2012
    Default please clear 01371008080 boxer 2011
    hi to all
    can any one help me to clear this Crash 01371008080 boxer 2011
    thanks advance.
    May 2017
    your clear file. test and back report
    PUSH THANKS AND REP IF I HELPED YOU
  3. The Following User Says Thank You to kotarski88 For This Useful Post:
    m1405 (9th April, 2020)
    m1405's Avatar
    Dec 2012
    not work ..
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Which errors before clear and after clear ?
    Best regards.
    Dragon
  6. The Following User Says Thank You to dragon100 For This Useful Post:
    m1405's Avatar
    Dec 2012
    For this car, the control unit was replaced due to water corrosion
    The original file is available after clearing the file. Unit control error is seen
  8. #6
    m1405's Avatar
    Dec 2012
    The original file is corrupted
    The problem was solved by replacing the healthy file and serial number
    free all no pass
  9. The Following 2 Users Say Thank You to m1405 For This Useful Post:
    networker (11th April, 2022), zbudo (7th December, 2021)
