Could you be more clear about what you mean?
in the lower speed range 900 rpm-2000rpm I have no more power.
he is not responding correctly or on time
x3nnyb (9th April, 2020)
First of all: Write what engine it is. Factory designation, capacity, power and year.
It they more information , it this more quickly can was get help.
VW Passat 2,0 Tdi 2006 BMP EDC16 140 hp
Did you check the DTC? Is the flow meter OK? Have you checked the parameters set and performed with some good program?
ok, i will turn off the dtc tomorrow, then i will keep looking.
Thanks a lot
Check the DTC first. Don't turn it off. It can be a simple mechanical repair!
it is exatly same in immo section - people not doing good diagnostic - only asking for mod files
need help
now my goal is to buy xp-005
who will help?
Hey mate, test this file i think will be better perfromance at all..
Pass in PM.
Hit Thanks and rep.
x3nnyb (10th April, 2020)
