I will adjust for you..
Stopro92 (10th April, 2020)
file is already HS fix but here you go
yes, already fixed..
Are you saying HS was already made in it?
check water temp. sensor
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
Sensor its ok, pump injector new, The car only starts hard when hot
So he increased even more at Hot start in file Brmservice?
this is ori file , HS soltion already applied
Yes, the compression pressure is a bit low, the car works mainly in the woods, so its condition is not sensational, that is, it wants it to start well when it is warm
test the file but I doubt it will be any real improvement. just above , check ECT values with diag.
when is engine cold how start ?
File Service
